M msauvage New Member Messages 2 Points 1 May 9, 2020 #1 Hi, My CAM are pluged into the NVR (POE) and the CAM are declared on a sub network. Is it possible to have the CAM and the NVR on the same network? Regards Michel
S Sonic007 Centurion! Trusted Member Messages 138 Points 28 May 10, 2020 #2 Yes. You can have the cameras plugged into the same network. The cameras would need to be plugged into a POE enabled switch to provide power and then that switch connected to your home network that also has the NVR on it somewhere.
Kyle Administrator Staff member Messages 1,505 Points 113 May 12, 2020 #3 It's explained in this part of the Megathread: Adding Hikvision cameras to an NVR
