Newbie IP/Subnet Camera address question.
Phil23
Hi All,
Newbie question regards my DS-7616 that I'm still coming to terms with.
Simple question I haven't found addresses in the doc's as yet.
My local subnet is 192.168.59.0, the NVR is on 192.168.59.39 ATM.
I have 2 cameras on the first 2 ports, IE 192.0.0.2 & 3.
But there are also 2 existing cameras connected directly to my network via the main switch,
at 192.168.59.64 & 65.
Can the NVR be configured to see & use these cameras, providing of course that I can identify the path to their stream.
Phil.
If they are either a compatible brand, or at least ONVIF compliant, then yes.
There's an illustration here at HikVision's YouTube channel (showing a method via a direct-connected monitor):
