stanislav77
Hey guys,
a friend of mine has a network which is made of 1 main Wifi router and 3 other routers (those are used to extend the Wifi signal). The routers are connected via LAN cable and the IP Adresses are: 192.168.1.1 | 192.168.1.2. etc. DHCP is enabled only on primary router.
My question is: is it possible to connect IP cameras to Router 2, Router 3 and Router 4 using POE injectors without any problems? The cameras will be used with SD cards so there won't be any NVR. The scheme would look like this:
IP CAM 1 --- POE INJECTOR 1 --- ROUTER 1 | IP CAM 2 --- POE INJECTOR 2 --- ROUTER 2 | IP CAM 3 --- POE INJECTOR 3 --- ROUTER 3
Thank you.
Thank you.
