Motion Detection 2.0 Ip Camera on Motion Detection 1.0 NVR
cosminpa
It is possible to filter the motion detection events by human and vehicle on Motion Detection 1.0 NVR if camera has Motion Detection 2.0 (Acusense)?
I am refering to Normal Motion Detection, not Permietral or Line Crossing!
Motion detection is on the camera not the NVR. Even if you have an older NVR, you can use an AcuSense camera to only trigger events caused by human and/or vehicle. The processing is done on the camera before sending the event to the NVR. Depending on the model of NVR and how new its firmware is will dictate whether the Human/Vehicle filter icons are present allowing you to show the timeline markers in normal playback and whether the motion detection page has the options to select. If you don't see the Human/Vehicle tickboxes in the event setup for motion detection in the NVR, it doesn't mean you can't trigger only on human/vehicle; it just means you will have to access the cameras web interface directly to apply that function. So you would do it like this:
  • In event setup on the NVR, setup your motion detection as you want - draw the grid, select the linkage actions etc
  • Go to the cameras web interface (using virtual host) and login there
  • Go to the event setup and tick the human and/or vehicle box then save
The camera will then only send the Human and/or Vehicle events back to the NVR.
