Hikvision has released new firmware for their G1 Series IP cameras. The latest firmware, Version 5.6.6, can be downloaded here.
NB - you may need to refresh your browser when viewing the Hikvision portal to see the newly added version at the bottom of the list.
The Release Notes are attached.
The last few pages of the release notes specify the applicable cameras.
Hikvision Firmware V5.6.6 main updates are listed below:
1. Fixed the issue that the main stream of the 2645FWD, 2745FWD and 2H45FWD model does not support 1280*720 resolution.
2. Fixed the issue that the wired and wireless IP addresses are set differently on Wi-Fi models. After unplugging the network cable, both IPs can access the device.
3. Fixed the issue that the algorithm does not detect the target after the device enable the Du-VCA function and runs for a period of time.
4. Fixed the issue that the SVC function of the camera is invalid after connecting to the NVR and enable SVC on the NVR side.
5. Fixed the issue of low volume pickup on some models.
6. Fixed the issue that Hik-Connect cannot be online for device registration due to changes in the rules of the virtual model of oversea products.
