OsoPolar
Hello Guys
After 2 weeks of Google, Discord and Reddit i have come across this site which i hope is my final destination
I am having issues in getting a Rstp or ONVIF my setup may seem funky to some but in the Hik Vision Hik Connect apps everything works.
The equipment i have is as follows:-
The paths i have tried are identical to what is listed in this site and several others i am just trying to get a view in VLC.
Path styles used
rtsp://admin:password@192.168.1.180:554/ISAPI/Streaming/Channels/101/
rtsp://admin:password@192.168.1.180:554/Streaming/Channels/102/
rtsp://admin:password@192.168.1.180:554/Streaming/Channels/101/
I have also tried to remove user name & password which ask for login but still fails.
The ONVIF software also provides a path rtsp://192.168.23.180:554/Streaming/channels/901 see here
If you need any further details or screenshots to help me fix they just ask i will provide anything you need.
Just hoping one you gurus can put me out of my misery trying to fix this.
- CCTV DVR Unit iDS-7208HUHI-M1/FA/A0820210328CCWRF71849545WCVU 192.168.23.180
- Intercom Panel DS-KH9510-WTE10120210124WRQ05434344CLU 192.168.23.182
- Modular Intercom Unit DS-KD8003-IME10120210106RRF37299528CVLU 192.168.23.184
- Dome Camera IP DS-2DE3A400BW-DE20210402AAWRF72793916 192.168.23.185
- Also 7 New Analog CAMs DS-2CE72HFT-F28(2.8MM)/GREY
The DVR i was informed by Hik Vision will provide my RSTP & ONVIF on all cameras. I know i cannot get an IP from the Analog cameras but as they have their own port on the DVR it will provide a view of each camera. But for the life in me having tried for over 20 hours over past few weeks no path I provide allows me to view it.
I am trying to get the images in Home Assistant i have used ONVIF integration which sees the DVR unit and the IP camera. See here
I have used Hik Vision Integration and it sees the following sensors of the Analog cameras see here
Path styles used
