K2 NVR Video Output resolution settings?
gp116126
Centurion!
Apologies for this very basic question.
Video output via HDMI of my K2 NVR is 1080P hence resolution of 1920 x 1080. It's connected to a 4K monitor, resolution of 3840 x 2160.
My cameras are set to record footage above 1080p resolution.
I'm presuming that due to the NVR's video output limitations I won't be able to view footage either recorded or in live view mode at anything above 1080p through the NVRs video output.
The only way I can view footage above 1080p is to download the recordings and play them on an appropriate device.
Woul appreciate thoughts / comments on my assumptions.
Edit.
Data Sheet says.
"HDMI Video output of up to 4k resolution".
So the question now is how do I change the settings on the NVR to achieve that as I cannot see the option. I am still operating version 3 firmware. It is the latest version.
Edit.
Data Sheet says.
DOH. Find the setting should have looked a bit closer. Sorry for my ignorance
No problem :)
If you could share what you found and changed it might help somebody else in the future, thanks.
Yes no problem Phil.
Remembering this is version 3 software and not version 4.
The setting to change both VGA and HDMI output resolution is found as an option in the General tab of the Configuration menu.
Click on the image below to see.
