IVMS4500 alternative ? (with push motion detection support)
derekz
Hi
Do you know android app alternative for ivms4500?
Important is PUSH motion detection support on camera.
thanks
do you have an NVR or just cameras and using the IVMS on a central Machine , would recommend Hik Connect if you can use it
Hik Connect will allow for the push notification (depending on the camera) the option should be under Network, advanced settings , Not sure how it will work on just one camera
One option is to setup email and platform access correctly in Network>Advanced Settings and you can set your motion events in Linkage Method to email you.
