richardc1983
Hi Everyone,
New member here but have been following the forum for a while now and have searched high and low for a definitive answer.
I have the DS-7208HUHI-K2 system installed since last year following upgrade from an older system with 7 ColourVu 5mp cameras. Cameras are not IP and are the 5mp coax wired dome-type. I just cannot seem to get good playback using the Android HIK Connect App. It's particularly bad on the playback of recordings. What I notice is that playback seems jittery and I have 30s pre and after for the recording but sometimes on playback the actual movement activation seems to be caught too late and you see the person walking come into view then they just disappear. Playing back on the NVR seems ok some of the time.
So about my settings and attached is a picture of the settings. I have played around with all sorts of settings to try get the best picture quality for the recordings etc but nothing I do seems to improve things and playback is either jittery etc. I have tried adjusting frame rate as it recommends a bitrate range so I put it halfway between what it recommends.
-H265+ enabled on all cameras.
-Bitrate as per attached.
-Firmware updated to V4.25.000 build 200925
-Combination of motion detection and line crossing detection.
-Within HIK connect I have the system added as an "online device" and use this when at home and then when I am away from home it is added by the IP address directly avoiding the need for the sometimes slow HIK connect servers.
Any help gratefully received on what settings should be what? Do I need to move from 5mp to 4mp? I have even tried moving the Main Stream Continuous to 1080p assuming that this may fix it but if anything it made it worse so now it is set to the same as event.
Should I turn off the + and just use H265 or even go to H264 or H264+?
Thank you
Richard.
Thank you
Richard.
