Issue with IDS-7208HUHI-M1S DVR Factory Resetting when the Power Cycles
Shiyar
good greeting I have a DVR HIKVISION IDS-7208HUHI-M1S I have a problem When the power is cut off from the device and after that turn it on, the factory reset will be done automatically Thanks
Hi Shiyar. After upgrade did you do a factory default? Maybe battery on motherboard is dead? Try replacing it.
Hi @Shiyar
Can you please confirm what firmware your DVR is currently running?
Welcome
The shop does not work. I changed the battery more than once.
I know that the battery work is to save the date and the hour only
But my problem is resetting the settings from scratch
Good day
I need dump file for dvr ids-7208huhi-m1/s
can you help
To download it to the flash by programmer
