Hi guys,
Recently installed Hikvision dvr system.
Turbo.
Along with 4 x 2.4mp dome camera's.
Issue im having is the image doesnt seem as sharp as i would like.
Im quite savvy when it comes to IT, but going through the on screen system menu offers little.
Adjusting sharpness doesnt help. In the PTZ section, focus doesnt adjust.
The image isnt to bad, just not as sharp as i would expect.
Have set to 25fps but not adjusted any other settings.
I have a cheaper system with 1mp cams and the image is a little clearer.
Using the camera toggle is an option but one id rather bypass if possible.
Maybe if settings not on the DVR, there is software i could link laptop to DVR to config camera to adjust focus?
Other issue is that one of the cams is quite poor at night, however, the other 3 cams are focusing at a distance of 5 or 6 metres over a driveway.
The cam with poor night/IR is aiming along a garden which is around 12 metre long. At night the rear garden is not visible at all.
So was thinking of adjusting the IR via the DVR.
The DVR IR settings seems to be greyed out so unable to adjust. Assuming i need to apply a certain setting to access the IR control?
Ive also just the Day/Night settings. Not adjusted them from default but Day=Standard mode and Night=Dim mode.
So to break it down, all 4 cams seems less sharp than expected and 1 cam is struggling with night vision/IR.
Many thanks for any help.
Turbo.
