A new I Series firmware version was reported on another thread by @dazulrich . It is available on the Hikvision website but not yet on the portal (thankfully). I've just discovered a major issue with this version.
Since the update the playback timeline, when smart is selected is practically a solid block of red. On closer inspection all cameras have reverted to the old motion detection - cell selection setup (rather than drawing a polygon). In the local menu, the Human/Vehicle filter in Settings > Normal Event > Motion Detection is missing. It's the same if you log into the NVR menu via browser - cell selection and no AcuSense filtering. Effectively the AcuSense filtering is being ignored completely. I've carried out a full power cycle of NVR and cameras but that doesn't resolve it so I've had to downgrade.
It gets worse (of course it does). The downgrade to 4.60.005 results in a factory default of the NVR restoring it to a de activated state. It's kept it's IP addressr but everything else has to be programmed from scratch.
Do not update to this version. If you already have, you may be better waiting for another newer version rather than attempting a downgrade as that is going to be time consuming....
@Dan - It may be worth highlighting this to Hikvision support
** Issues resolved in later build date firmware as highlighted by @dazulrich in post #6**
