How to adjust the lens focus of the Vivotek FD8134 dome IP camera
Just as a tip, when following this guide, if you take the illumination board off (this is if you are focusing in daylight hours). Then remove the rubber central light shield, then re-attach the illumination board, you can adjust the focus live, rather than having to turn off, remove board, make an adjustment, reassemble, test etc.
Harv
