How do I program the door station camera on a 2nd generation Hikvision intercom to a Hikvision nvr I tried manually adding the station IP address using hik protocol and port 8000
Was in Poe switch but programmed to lan two house network wil change settings to lan one network camera subnet was under the impression if nvr set to multi network it would pick up the settings settings on either network of the nor
