I IA Sudip New Member Messages 3 Points 1 Nov 8, 2024 #1 I have NVR DS-7104NI-Q1/M and I am unable to access my NVR using RTSP outside LAN network.
trempa92 Centurion! Trusted Member Messages 183 Points 28 Wednesday at 12:17 PM #2 Can you access it locally in same network? If yes Then you need to open port / use dyndns or static WAN ip address. Or set up a VPN connection to NVR network.
I IA Sudip New Member Messages 3 Points 1 Friday at 2:21 AM Thread starter #3 trempa92 said: Can you access it locally in same network? If yes Then you need to open port / use dyndns or static WAN ip address. Or set up a VPN connection to NVR network. Click to expand... Yes, I can access camera and NVR in same network. appreciate for guidance.
