Currently, we only offer the (B) variant of Hikvision's 7604-K1 NVR:
Hikvision DS-7604NI-K1-4P | 4 Channel Network Video Recorder ¦ use-IP Ltd
We were led to believe that this '(B)' variant was an updated replacement for the previous version without the (B) suffix.
It came with the introduction of the h.265+ CODEC as an option on that base model NVR.
However, I am keen to share something that has only just come to light:
The previous version 7604 (without the (B) suffix) had ANPR capability built-in.
The newer version (with the (B)) is not ANPR capable.
Both remain available.
We were originally led to believe that the (B) replaced the original version.
This happened months ago.
The absence of the ANPR capability in the (B) model has only just come to light (initiated via a question in this forum if I recall correctly).
In the next week or so we will make both variants of their 7604-K1 NVR available in the webshop.
Last week, we began working through our NVR offer and added more attributes that you are now able to filter them by e.g. RAID, Dual LAN, Dual monitor & ANPR. This helps to make these key attributes more evident, and enables you to select for specific features that you may wish/need.
