Please note that ONVIF is disabled by default in this latest V5.50 camera firmware version.
If you need to use ONVIF compatibility, to record your HikVision cameras on the NVR of another manufacturer for instance, then you will need to enable ONVIF first:
https://goo.gl/PDs96h
