Hello everyone. Great forum you have here, very informative.
I have a question regarding a DS-7616NI-I2 / 16P NVR. When viewing full screen a single channel using the main stream the picture freezes for about a second every 20-30 seconds. Playback of the footage during these freezes does not show any freezing and plays fine. Problem is I need this stutter free as it will get annoying while monitoring. Any ideas?
I'm using DS-2CD2185FWD-I cameras and the following settings.
Resolution 3840*2160
Bitrate Type Variable
Video Quality Highest
Frame Rate Full Frame Rate 20 fps
Max. Bitrate (grey'd out at 8192 Kbps) Due to H265+?
Video Encoding H.265
H.265+ ON
I have factory reset the cameras and NVR after firmware updates and are currently using the following firmware.
NVR Firmware:-
Firware Version V3.4.92 build 170228
Encoding Version V5.0 build 170228
Web Version V4.0.1 build 170124
Camera Firmware:-
Firmware Version V5.5.3 build 171018
Encoding Version V7.3 build 170929
Web Version V4.0.1 build 170711
H.265+ ON
NVR Firmware:-
Camera Firmware:-
