talksr
Hello,
I have a HikVision 8MP DS-7604NI-K1/4P POE NVR with a 10TB HDD and 2 x DS-2CD2385FWD-I 2.8mm cameras.
The NVR has two direct ethernet connections going from the back of it direct to each camera with two more ports spare.
I am thinking of installing a POE outdoor switch using one cable so I am able to add two more cameras to the NVR but without running individual cables to each camera.
Does anyone know if this would work? The POE is not an issue as I have a POE switch next to the NVR if needs be, but my question is, will the NVR detect the IP cameras if they are connected into a switch rather than direct to the NVR?
Also, just out of interest, does anyone know if the more modern HikVision cameras would be compatible with my NVR. Say a DS-2CD2367G2P-LSU/SL?
Thanks in advance
Thanks in advance
