Hikvision NVR Noise figures
CHris S
Hi.
I have been looking at the Hikvision data sheets for NVR noise,specifically from the fans and so on . I cannot find any published dB figures for the NVRs.
Am I correct in this assumption ? I am considering replacing my DS-7608NI-K2 / 8P - it performs really well but the noise drives me up the wall. If necessary I'd consider a single network channel NVR and use a silent PPOE brick to cut out the need for the high power fan .
Basically - what's the quietest NVR I can get ? I have no interest in moving the NVR from where it is and I've tried every fan combination including a bunch of noctuas
Thanks in advance
The latest model 7604 is fanless:
Thanks for this. is there a feature comparison anywhere for that stuff - I have a couple of 8MP cams . Also cant see a price and my login doesnt seem to work ( are they different logins for here and there ? ) ....
Yes, you need a separate login for the webshop at the moment
thanks. Got in thanks. Any differences beyond 4 channels to 8 between the two ?
yes thanks but I meant other things like HIK-connect, motion detect and so on - any other functional differences ?
Which is the Best Hikvision NVR for 8 Cameras?
