I have a new Hivision 4 channel Hikvision NVR as a replacement for a Dahua NVR that crapped out. I am so far unable to get the NVR to recognize the existing 4 cameras that I have connected. I suspect it is an IP address issue but as yet I have been unable to resolve it.
The existing cameras are Dahua IC-IP9113-28 (HDW 1320S), POE, ONVIF compatible. I removed one of the cameras and have it in hand. Since I suspected that I needed to find a way to modify the camera's IP, and I did not have an external power supply for the camera, I bought a POE injector. I plugged the camera through the POE injector directly to a switch, which is connected to my router. The NVR is also connected to the same switch.
When I login to my router I can see the camera - it has IP 192.168.1.108. In an attempt to modify it's IP, I downloaded the Hikvision SADP from their website and I also downloaded "Config Tool" from Dahua, which contains and SADP as one of it's tools. I also downloaded the Hikvision iVMS-4200 tool. I tried launching all 3 of those tools, but none of them could see the Dahua camera. The two Hivision tools (SADP and iVMS-4200) could see the NVR (since it is connected to the router). However, the Dahua Config Tool could not see the Hikvision NVR.
So this is where I am stuck. Looking at the camera datasheet it appears to be ONVIF compatible and I thought that would allow it to be visible to the NVR, but maybe those cameras won't work with this NVR? I am an Electrical Engineer but my knowledge in this area is woefully lacking. Appreciate any help. Thanks, Ed.
