Hi, I’m looking at making these changes aswell what voltage do the fans need to be? I’m going to buy the ones you recommended....Hi Phil,
I sourced my fans from amazon.it. There's also the 2cm thick version Noctua NF-A4X20 but since i just have 4 camera using the POE from NVR i went for the lower noise and lower airflow version of 1cm thickness and didn't have any problem in the last 3 years.
For sure the warranty will be affected since you have to open the power supply and cut the cable of the original fan that has a non standard plug.
Hello, Would you be able to provide me with the product that was used. I am in need of copying this idea and solution!The 7700 series NVR is also very noisy. A client of ours complained about the noise because the NVR is in his living room. The PSU fan is the real noise maker on this model. To avoid warranty issues we installed sound dampening foam while maintaining airflow.
Any foam/felt feet on Amazon will do the job. Most of the noise is not the fan but the airflow through the hole punchings. Even with the standard fan the noise is barely audible with the lid off (though there's not much you can do for the models with an internal PSU and fan)Any recommendation for anti-vibration rubber/silicone feet for NVR? It has metal feet and they amplify the noise when sitting on a hardwood shelf etc.
I didn't. I have mine in the roof space so don't hear it. I wouldn't install an NXI-I, I, or M series unless it could go in a cupboard or loft space. I did a 7716NI-M4 a few weeks back and that has a much larger (80mm maybe?) case fan as well as one on the PSU. I couldn't have put that where it was audible.How did you fix the noise issue?
