Hi all,
I updated the firmware on my NVR to FW 3.4.92 and all my static camera's to FW 5.5.0
All went well and everything is back up and running bar one issue.
Due to location I have 4 camera's attached via a POE network switch. I patched in their IP address into the NVR and they work perfectly fine.
The problem is I have one camera that plugs directly into the NVR. That one no longer works and I have narrowed the problem down to a POE issue. The camera itself is fine as I have tested it with an inline POE injector then into the NVR and also plugging it into the POE network switch and it works both ways.
So, I have been tearing my hair out how to get it to work attached directly to the NVR ? It worked perfectly before the upgrade so it should really still work unless the FW has killed off any POE in the NVR.
I also updated the NVR FW up to 3.4.95 and it's the same. POE direct from the NVR doesn't power the camera any longer?
Can someone help please as to what the issue could be?
I have read some threads saying that you can try enable long distance mode on the NVR post FW 3.4.92 to see if that helps. I would like to give that a try but unless I'm mistaken I cannot find anything in the menu's ?
At a loss at the moment.....
Thanks for your help
