HIKVISION DS-2CE56H1T-ITM - DS-7204HUHI-F1/S - Ghosting
Alan Walker
Good Afternoon,
I wonder if you could advise me please.. The picture is great, good quality, but if you have a building with the light behind it, you get ghosting from the building
Can you advise what needs to be changed please…
All the best from Alan
Hi Alan, can you explain further please?
"if you have a building with the light behind it"
Good Evening Phil, I will do better, photo attached...
all the best and Thank you from Alan
Hi Alan,
I don't think that ghosting is caused by the backlight / sky.
I guess you'll see a similar effect if you point the camera at something else, in the other direction.
I'd checkout / rule-out / replace the co-ax cable and BNC connections first.
See if you can get the camera on a short cable, or better still a factory-made cable and see if you get the same effect.
Good Evening Phil,
You are quite right, it does not matter where I point it there is always shadow/ghosting
tomorrow I will go to Maplins and get a shorter cable.
It is on a standard 20meter cable, 3m thick wire.
I will let you know how I got on...
Thanks again
Good Afternoon Phil,
I disconnected the Video cable and put 50ohm coax in place 5 meters, and it is perfect..
That leaves the final question, where can I buy decent cables from :)
All the best and thank you from Alan
