HikVision 7208 - setting up alarms?
Stu_c
Hi all
I want my unit to be able to turn out flood lights on automatically when it picks up movement is this possible to do this with this unit? I don't know if I need to put separate replays in to do this or can the device handle a 240V?
The specs for the unit don't mention voltage handling at the alarm outputs, but as there are no relays inside the unit, I would think they are low voltage. I certainly wouldn't want to connect 240v to them. As you say, some sort of relay switching unit would be required.
