Hikvision 1280zj gland size
Apples12
Hi all,
I've got 3 hikvision 4mp bullet cams and the requisite 1280zj bases
However, I cannot seem to find the proper cable glands to waterproof the ethernet cable going into the bottom.of the 1280zj base
Does anyone know/willing to share the sizes or a link to purchase?
They are 3/4 inch thread which were not easily available in Australia.
Here is what I posted in another forum about my solution. You should be able to find the metric versions a bit more easily in the UK rather than imperial?
"I replaced the glands with 25mm ones from Bunnings which I could run corroguted conduit into.
DETA 25mm Corrugated Conduit Gland
They don't screw directly in so you need a locking ring for the inside and the one the gland comes with is too large in outside diameter to fit.
DETA 25mm Threaded Lock Ring
You can also just shave off the side of the included locking nut but at 21c I couldn't be bothered."
I then ran the network cable in corrugated conduit to protect it.
Sorry, sad but true, if I recall correctly Hikvision use 3/4" BSP as the thread for their glands :(
