I have recently had to connect my Sky Q box to an ethernet cable via a powerline adapter, as soon as i do this, Local device on Hik Connect cant be found and i cant reach the NVR through a web browser. Both NVR and Sky Q box have reserved ip adresses. As soon as i disconnect the ethernet from the Sky box and use wifi instead, the Local device NVR becomes available again in hik connect. I can still see the NVR/cameras through Hik Connect if the sky box is connected or not, it is only viewing through local devices that stops working.
