AndyoSurrey
Hello All
I have a small home Hikvision installation with four IP cameras (three POE and one Cube Wifi) and a 760NI NVR running the latest firmware and the cameras and the NVR. When I am out of the house I like to be able to alter the alert settings on my cameras - and need DDNS to work to do this. I have a weird issue where I have added my NVR to the hik-connect database and on the online portal I can see the address/80 allocated. However when I click on this address (it is a hyperlink in the database) it actually connects to my Cube IP camera instead on a different local IP address. I have deleted and re-added and each time it just points my NVR at the wrong local IP address. When I add the Cube camera as well it just uses the exact same address. It seems that the NAT table for my account is stuck somehow on one target IP address.
I have logged a question with Hikvision using their UK email address for support but have no response.
Hoping someone has seen this before and can help me out as I've spent many many hours going around in circles.
Cheers
Andy
Cheers
Andy
