Hik-Connect Hik-connect daytime playback not working on my iPhone?
flyby
I've seen this mentioned a few times, with no available solutions.
I have 5x DS-2CD2387G2-LU 8 MP ColorVu cameras and NVR DS-7608NI-I2/8P. Since upgrading the firmware to the latest version, hik-connect playback on the iphone rarely works for daytime footage. Nightime playback is fine.
Over a period of weeks, I have tried all the different settings, which had negligible impact. Currently settled on 265+ and 4098 max bitrate. I have no problem with smart events and 265+.
When I recently purchased the 5th camera, I didn't upgrade the firmware and it still has the original factory firmware V5.7.3 build 220112. This camera works perfectly and plays back daytime footage. So I think this problem of no daytime playback is either firmware related or an obscure setting specific to the newer firmware.
For those still reading, the new firmware I am using on the NVR and 4x cameras is V4.60.005_220927 and V5.7.10_220830 respectively.
Would love feedback from anyone else.
Hi @flyby
The first thing to do is update the NVR firmware, as I know some of the earlier V4.60.X versions had a few Hik-Connect bugs.
It's available at the bottom of this page:
The cameras are all up to date :)
Also, what version of Hik-Connect are you using, and is this on Android or iOS?
I'm downgrading my cameras from V5.7.10_220830 back to V5.7.3 build 220112. (I am a bit worried about going to 5.7.11 with no downgrade possible)
I have one of my systems DS-7616NI-I2 / 16P (V4.61.025 build 220905) and my 3 8MPs cameras and 4x4MPs were upgraded to V5.7.10_220830 and observed few issues
DS-2CD2386G2-ISU/SL
DS-2CD2T86G2-4I
- No daytime playback in Hik-connect for NVRs added via Hik-Connect domain (unless I am connecting to NVR via local IP using Hik-connect app where it works)
- I can playback daytime recordings that were recorded when camera was on V5.7.3
this issue doesn't affect my 4MP cameras upgraded to the same version, only affects 8MPs cameras. No change to Hik-connect app. (V4.26.1.0930) - I have Android phone.
I also lost 2-way communication from Hik-connect app. (downgrade fixed it)
And Smart Line-Crossing events were no longer working for me either in 5.7.10
Hi @flyby
Hi, I'm an Australian user. The supplier told me I can use Aussie or International version firmware, so I'm using firmware from the Hikvision Australia website, and I have the latest currently on their website.
Would the UK version work? I haven't been able to locate the 'international' firmware site.
I'm using iphone hik-connect 4.27.1.20221018
DS-2CD2386G2-ISU/SL
DS-2CD2T86G2-4I
I also lost 2-way communication form Hik-connect app. (downgrade fixed it)
Hi, interesting you appear to have the same problem. I don't have any issues with smart events though, just daytime playback on camera firmware v5.7.1
Let me know how you go rolling the camera firmware backwards.
I rolled back to V5.7.3 build 220112 and that didn't help (but i didn't reset camera settings to default, so I may need to do later today/ tomorrow to see if that works). I think after about 6 timeouts, it says "no more connections allowed" and I have to restart NVR.
I found this article wih the same error code 260015
: https://securitycamcenter.com/hik-connect-video-playing-failed-error-code-260015/
I did play with the max bitrate for cameras and set to 16384Kbps , so it may be that Hik-Connect servers struggle. All is OK when I play recordings via direct IP connection (VPN).
Hi, this has fixed my problem. After months and months of playback not working, I can confirm, updating to NVR firmware V4.61.010 Build 220527 (from US website) has fixed it.
