A.B
I have connected 3 ip cameras in the house with router , mobile and cams close to each other as per instructions,all connected fine and worked, when I unplugged them and moved outside none work, no internet , I have a wavlink poe outdoor antenna / repeater in between the cams and router, the repeater has the same wifi key as the router any help would be great thank. UPDATE, I have just repeated the operation but I took the router outside connected all cams again, when I disconnect the router and take back inside reconnect the power , same thing again, all cams have no internet. Why do they lose the wifi signal when moved ? HELP.
