Firmware for HiLook IPC-D620H-Z
Mr_Sjappie
Whhat firmware should I use for this camera: HiLook IPC-D620H-Z ?
I think it is the same as Hi-Watch.
According to a list from Hi-Watch it would look like I can use the G0 firmware from Hikvison. Am I correct ?
Cheers.
Cheers.
In the Hikvision Download portal you will see a folder for HiLook and inside that folder, there is a spreadsheet for which firmware is compatible with each model, yours would appear to be compatible with the E3 Family firmware.
