Hi All,
Does anyone know the correct firmware required to upgrade the above from V5.3.0 build 151016.... I downloaded the file from the product page download link: DS-2CD2E20F-Hangzhou Hikvision Digital Technology Co. Ltd.
When extracting the notes stipulate the following:
_________________________________________________________
****** IMPORTANT - MUST READ and FOLLOW ******
Please check your current device firmware version before upgrade:
Scenario 1- If the version falls into the range from V5.2.0 build 140721 to V5.4.0 Build 160530, you need a 2-step ugrade process. Note, if the step was skipped, your device may fail to operate normally.
1) update to V5.4.41 build 170310 FIRST, reboot
2) update to v5.4.5 Build 170123, reboot
Scenario 2 - If your firmware is newer than V5.4.0 Build 160530, you can upgrade to V5.4.5 Build 170123 directly.
For HiDDNS user:
Please note, if you're using HiDDNS service connected directly to this IP camera, please upgrade to v5.4.41 build 170310 only. Starting v5.4.5 Build 170123, HiDDNS service is no longer supported but Hik-Connect.
_____________________________________________________________
Closest I could find is the following link: Hangzhou Hikvision Digital Technology Co. Ltd. but doesn't seem to reference my specific hardware...
Any chance of any pointers?
Cheers,
Matt
For HiDDNS user:
Cheers,
Matt
