Extending NVR with wireless bridge
raptoruk
Have a 1 camera(PTZ) in a farmhouse and need to wirelessly bridge around 300 meter's to a barn with excellent line of sight.
What is the best Wireless Bridge that I can plug directly into the POE port of the NVR to keep it simple...?
Only seen these so far..?
Ubiquiti airMAX NanoStation Loco 5AC Wireless Network Bridge
Thanx in advance..
I'm planning to do something very similar in a few days. I purchased 2X Ubiquiti NanoStation Loco 5AC - one to go at the camera end, one to go at the main network end.
I have also purchased a POE switch to power the camera and nanostation.
I believe you set the camera end to station mode and the other end to access point mode.
Originally I intended to plug the main access point nanostation into a POE network switch however I am now thinking that I could set everything up with static ip addresses on the same ip range as the network switch in the NVR, then plug the nanostation directly into the NVR then change the channels from plug and play to manual and set the ip of the camera manually.
If anyone has more experience in this, it would be good to hear what you think.
We tend to discuss such things with the specialists at WiFi Gear.
We used to use their Deliberant products, which have now been renamed/replaced with Ligowave.
We have used these across farms, and busy industrial sites:
Spoke to Chris @ WiFi Gear.. top bloke.. and knew just what I needed.. parts ordered.. TY
