Jaso912 Active Member Messages 49 Points 8 Sep 27, 2018 #1 Hi I have a hikvision cctv my model number is DS-7604NI-SE-P don't no if it needs firmware updates or the hard drive is on its way out please help
Phil Administrator Staff member Messages 5,133 Points 113 Sep 28, 2018 #2 The latest firmware for your NVR is available here: DOWNLOAD PORTAL You may be able to see some clue in the NVR's logs or HDD health in the Configuration section.
Jaso912 Active Member Messages 49 Points 8 Sep 28, 2018 Thread starter #3 how do i down load to a stick thanks
Jaso912 Active Member Messages 49 Points 8 Sep 28, 2018 Thread starter #4 done the update thanks fingers crossed its sorted it thanks again
