Door Entry DS-KV6113 factory (or password) reset
Julf
Typical stupid thing. Did a quick test setup of my door phone system, and set a password that I thought was easy enough to remember, so I did not write it down straight away. Of course I forgot it. Is there a way to reset to factory defaults?
Not with this model as it does not support a physical hard reset button.
After you have had the password reset using XML file this time, you can then set up one of these 4 reset methods so that you can reset the password in the future without contacting the vendor.
Thanks. I am rather surprised that there is no physical hard reset - it shows a rather strong faith in the quality of the soft/firmware... :)
