Hello all,
I've recently purchased the above NVR for cameras I've had for a little while.
I've got 2x DS-2CD2785G0 and 2x DS-2CD2786G2 of which only one is online at the moment. I also have a KD8003 intercom.
The issue I seem to have is its ability to live-view and playback anything from the 2CD2786G2. Up until last night, everything was being recorded at H.265, + was off. The other cameras have been and continue to be OK, but the one in question was showing spotty, intermittent recorded timeframes, and when there was some indication of a recording, it would display maybe a second or two then freeze. Enabling H.256+ seemed to resolve the recording consistency, but its ability to playback is still not consistent. What I can seem to see is that any nighttime recording seems OK, but at some point after transitioning to daytime footage it will freeze, but there isn't anything I can find that will determine why.
I'm constantly recording to a 8TB WD Purple, of which I have two installed. I've just this morning split these sources across both HDDs, though the BW to the disk is well below what it can do, as well as to/from the NVR itself.
From a topology perspective, the two G0 cameras are on the same switch, while the G2 is two switch hops away, but all on the same network.
From iVMS, there are no issues experienced connecting to this camera, the PC on which the SW lives is the same "distance" away from the camera as the NVR is.
The settings on these cameras is identical insofar as the resolution (4k), framerate (20fps), bitrate (constant/16384), etc (except for the KD, which are the highest settings relevant to it). The recording settings are also identical. No camera is defined for any default live-view setting.
I have basic motion detection setup on all cameras, and one smart detection event setup on one G0 camera.
The general motion detection setup is not quite what I want yet, but for the purposes of discussion, they'll remain as-is for now.
The FW of the G2 is V5.5.800.
No logs show anything that would indicate any type of issue.
If there's something odd with the camera in question, I'm all ears. I have the second one that I'm going to bring online soon enough and while I'm in some window of return for this NVR, if there is something specific to the NVR, I'd rather sort it sooner than later.
TIA
TIA
