Just noticed this seems to be the latest offering
Interesting. @uvs-300 it looks from your title that the file has been updated again since you posted. I just downloaded your linked file from the global site then checked the UK site. 5.02.008 has appeared there also in the last 24 hours but with a different build date. UK site is 240419 the same as your thread title but the file you linked is now dated 240425. They're the same size so I'm not sure if there's any difference.Just noticed this seems to be the latest offering
Think it was me...I had previously downgraded to v4 but decided to take the plunge with this new version. Cameras that are connected to the NVR are working fine but the Doorbell and a Hikvision camera on the main network are no longer being recognised.
iVMS says they are disconnected and then NVR Web UI shows:
I vaguely recall reading a post which explained how to resolve this, but cannot seem to find it now. I would greatly appreciate it if someone could point me in the right direction![]()
Think it was me...
I had a similar situation - a video doorbell on the main network. You also need to do the above if you have PoE connected cameras that are manually configured rather than using Plug and Play.
- Device Access > Device Configuration > PoE Settings - switch off the 'Network Camera Plug and Play' switch for POE 1 and POE 8.
- Device Access > Device > Video Device - add them back in again
I don't recall needing to do that but several other users have reported similar. Only guessing but perhaps I added my doorbell in with the very first iteration of V5 and the 'Device Type Mismatch' issue was introduced after that first version.Thanks. I'm getting a "Device Type Mismatch" error for the doorbell/intercom. Changing it to HIKVISION_RTSP seems to work. @JB1970 did you have to do that as well?
I would say thats normal. If you purchase a new NVR, Motion Detection is enabled across all channels. Going between major versions (V4 to V5) may switch Motion Detection on when it was not previously (though the configured motion area if not full screen will likely be maintained as it's a camera side setting)Most of the event (line crossing, intrusion etc) settings are still present, but motion has been re-enabled for all cameras (it was disabled before). It isn't going to take me long to reconfigure each camera so not a big deal. Is this to be expected when upgrading from v4?
No dumb questions there and no apology requiredApologies in advance if the above is a dumb question. I only started working with HikVision systems a few months ago
