DS-7608HUHI-F2/N POOR IP CAMERA RESULT
hafiz ijaz
Hi.
I have purchase the HIKVISION turbo ds-7608huhi-f2/n model. I am having trouble with the ip camera.
it is working fine with analogue camera. when i connected the hikvision ip camera ds-2cd2355i,
the video is very slow(people are moving very slowly), missing frames, not smooth at all. I tried all the possible setting changing frame, bit rate, resolution, encoding but no joy. and if i connect Dahua HDBW4431R-ZS, same result plus it give me warning of bitrate mismatch. and when i select encoding H.264 in the camera then dvr does not allow me to change any camera video setting and set the the resolution 1280*720.
I have another model DS-7608NI which work perfectly with the same cameras.
Any suggestion or thoughts are much appreciated.
Thanks in advance
