Hi all,
Just a few questions about the NVR settings please.....
Under Advanced configuration and platform access there is a setting "Enable Hik-connect Server Time Sync".
Should this be ticked or not?
I have my NVR time set to update via NTP server.
Just wondered what this "Enable Hik-connect Server Time Sync " was.
Secondly, should H.265 be set to off as it is now and H.265 selected or the H.265+ setting turned on?
Is there a way to assign a SSL secure certificate to the NVR and do you reccommend one to use?
Thankyou for your help.
