Connecting single PoE Hikvision IP camera
nsadmn
Hi everybody
i have bought one hikvision ip poe camera, the model is ds-2cd1021-i
i want to make it working with normal usual power adapter 12volts 3a
the end on camera side is rj-45 connector with all 8 pins ( B type ) and the on the other
side is rj-45 connector with 4 pins only orange and green as usual need for network to work
and the spare pins brown (7,8) pair and blue pair (4,5)are to give power to camera
is it possible to connect them to power adapter brown pair as negative and blue pair as positive and make camera working
as if it is connected to poe switch
could i be clear
regards
I don't think you'll be able to get it to work in this manner.
POE power is provided at 35-57 volts DC, so that is what the camera will be expecting via the network connection, its internal electronics reduce this for its circuits to use.
http://www.hikvision.com/upload/20170605030116551.pdf
thank you so much
i understood, thats interesting that camera is expecting 35-57 volts via network side while it is enought for 12 volts to work via usual power adapter side
the info was helpful for me, thanks again
regards
