Colorvu white light coming on in daylight hours when set for motion trigger?
davidhewitt22
My colorvu cameras G5 white light is coming on in daylight hours aswell as night when it set up as a trigger for motion detection,
Is there a way to adjust the lux level on these when it is used this way?
I don't think so, I found the same when I tried it out. If the alarm is active so are the linked actions. The only way around it would be to either set a schedule on your events. Or alternatively you could set up a second event type covering the area you want. So you would have motion detection 24/7 with no white light linkage and line crossing/intrusion detection scheduled nighttime only with white light linkage (or vice versa)
