Good morning everyone,
I've recently joined the forum after looking at a setup for a home install.
I've got all wiring on place already and mostly deicded which NVR I require (Still unsure if I should just take an 8 Channel) but I seem to be stuck on choosing which cameras to purchase.
I initially wanted to choose the ColorVu camera but have been advised elsewhere that the white light will be on permanently (At night/Low light level) which may not be ideal. Watching videos on Youtube implies that it can be turned off via the web browser GUI if required?
What I like about the Acusense cameras is the function to be able to flash the white light when motion is detected.
Is that feature available on the ColorVu camera?
I think a 4mm lens would be sufficient for my needs.
The cameras would be fitted to a property set back from a street so the back garden and drive way can be relatively dark with street lighting possibly 20-30metres away.
Any thoughts or advice on the differences between feature sets of each of the ColorVu or Acusense cameras would be greatly beneficial.
Many thanks
Many thanks
