stanzanim Active Member Messages 32 Points 6 May 23, 2019 #1 as per subject, I am trying to register two DS-2CD25555 FWD IP CAMs by entering the S/N (e.g. C123456789) but says 'cannot register this device' I did not try the QR code (is it on the CAM?) but supposedly I can register by S/N Please help
Phil Administrator Staff member Messages 5,133 Points 113 May 23, 2019 #2 Have a look at this thread: Hik-Connect portal error message "No device is found. Make sure that the serial No. is correct and the device is connected properly."
stanzanim Active Member Messages 32 Points 6 May 27, 2019 Thread starter #3 I checked all points 1-9 in that link and it still does not work One question: the router address is meant as default gateway address right?
Phil Administrator Staff member Messages 5,133 Points 113 May 28, 2019 #4 stanzanim said: One question: the router address is meant as default gateway address right? Click to expand... Yes
