Yes.
Use the Sanyo VMS software to record the combined feed from the IP camera to your PC, laptop, server.
You can also extract the files for other use as video clips with audio.
Use the Archive Export tool in the VMS software and select either the .asf or .wmv file formats (audio won't work with .avi). With the .asf format be sure to set an appropriate frame rate (e.g. 25fps) and bit rate (e.g. 10,000Mbps).
