Hi Guys,
I've had my CCTV system installed for years now but this week 1 of my cameras lost connection and I can't seem to figure out why. I have 3 cams connected via POE to the NVR which are working fine, the issue cam is connected on the LAN via powerline adapters and a POE injector at the camera end.
If I webview the IP of the issue cam I can see live view working OK, the issue is that the NVR no longer sees this camera.
I've updated the firmware from 5.5.5 but still cannot view it on the NVR. Also tried changing the IP address on SADP tool as well as the NVR web gui but still it shows Offline(Network Abnormal) as the status.
NVR - DS-7604NI-K1/4P
FW v3.4.98 build 171121
Issue Cam - DS-2CD2042WD-1
FW v5.5.82 build 190909
Any ideas on what I can check next?
Thanks,
Craig
Thanks,
Craig
