Built-in POE NVR
Are the built-in POE NVR's gigabit and what is there range.
Gigabit network port but 100 Megabit PoE ports. Standard 100m range but there’s a per channel extended PoE option in the settings that will enable longer distances (200m I think but can’t remember). The max resolution, bit rate etc possible is affected by the actual cable length when that setting is used.
