Are there any angled mounts for Hikvision mini dome cameras?
Spanky Deluxe
I think the answer is no based on Hikvision's confusing flow chart on their site but I thought I'd check here. I've got a couple of
DS-2CD2542FWD-IS last gen 4mp mini domes and DS-2CD2563G0-IS current gen 6mp mini domes that I've been putting up but could really do with more of an angle if I want to mount them where I'd like (higher up on exterior walls). I'm guessing I'll probably need to fashion something myself. The current gen ones use 3 screws whereas the older gen use 4. Now I *really* wish I had a 3D printer!
Unfortunately, no - there are no inclined mounts for the 25XX flat-domes :(
I had an angle bracket meant for turrets. I mounted a mini bullet on it as I needed beyond 90 deg tilt. Basically drilled holes in it, screwed it in with proper sized drywall screws. Its pretty solid.
Hikvision DS-1281ZJ-M Inclined Mount
