Ben Bullen
I'm sure there are actually loads of reccomendations on here already, but my situation is quite specific so any advice most welcome!
I've currently got an old SWANN cctv system in operation at my house, but it's a little rubbish now in all honesty. The resolution is really bad and, although it keeps a recording, I would like remote access on my phone to monitor the house whilst I'm away.
We're currently having an extension built so now it an excellent time to upgrade! But upgrade to what? I've got a synology rackstation which runs my home entertainment. Obviously it could be used as surveillance station too, but I'm not convinced it's the best way to go? Not to mention the fact that it only comes with a license for one camera so if I want 8 then that's a lot of licenses!
Would it be better to keep the two separate? If so, what system should I look at in order to give me access remotely?
I should also add, the biggest headache I've got with this is that, because we live in the middle of nowhere with terrible landline broadband, our broadband is provided by a 4G router and SIM from THREE. That means I'm not on a fixed IP - nor can I get one without spending a lot of money per month on a different SIM (which also wouldnt' give me unlimited data) So I'm stuck with THREE at the moment... Can it be done using DYNDNS instead?
In terms of camera resolution, 720p should be ok I think, although 1080p would be nicer!
Thanks in advance for any advice...
Ben
Ben
