Any HIKVision IP Cameras working standalone without DVR/NVR
ais11
Hello all,
Wondering if someone can answer me. I wanted to buy HIKVision Fisheye IP camera but seller told me it works through NVR only. I want to use it standalone. Do you guys know if it is all HIKVision IP cameras or there are some models available which can work standalone without DVR/NVR? Thanks in advance.
yes you can use any hik ip camera without a nvr/dvr
you will need a source to power camera if you switch doesn't have POE built in
or a poe injector or you could use a power supply locally to the camera location using the fly lead to power it and just run the cat5 cable to you router/switch
you can use the internal sd card reader to store images or use a nas box
Thank you very much for your response. I was about to buy on ebay but their description was misleading so wanted to confirm. Thanks again.
Could you consider the new Milesight 12MP fisheye camera?
Milesight UI-9F74-PC 12MP Fisheye Network Camera
Just released (stock arriving next week), latest technology, works standalone.
FYI - newly uploaded YouTube video from HikVision Tech Support regarding HikVision Fisheye integration with their NVR:
