ANPR Setup issues
Is it allowing you to Save and carry on?
The HikVision camera is informing you that if you enable this advanced function (ANPR) you will not be able to use three video streams (the third stream it is referring to).
I can't recall whether that model/firmware has a tick box in its settings marked 'enable third stream'?
If it has, it's asking that you untick that before enabling and setting up ANPR.
